Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
26/6/08 - A loud clonk!
My Jimny has gained a significant clonk when letting up the clutch, there is also a lot of drive chain "shunt" and rubber "squeaking" whenever the back axle is exercised in any way.
I have crawled underneath and pushed and pulled things.
  7603 Hits
23/06/08 - What tyre size
The most common question asked about Jimny's is what is the largest tyre size I can fit on a standard vehicle.
  18320 Hits
Tags:
18/6/08 - Damaged axle - update
When I returned from Avon Dassett the other week my rear wheel bearing had failed.
I have replaced the wheel bearing and just taken the car for a test drive.
There is a lound "Rub Rub Rub" noise, consistent with the rotating of the wheel. Its loud enough to almost be a "Clunk Clunk Clunk" noise.
The noise stops when I gently apply the brakes whilst driving.
I have stripped the drum off and I think I can feel some sort of "Rub" in the system as I rotate the axle shaft by hand.
I have also taken this video of what looks like a wobble, but perhaps the centre ring is not straight anyway?
Is the axle shaft bent? Is the axle housing bent. Strangely enough when I had the shaft out I did think I saw a slight twist in the splines.
http://www.bigjimny.com/images/phocagallery/videos/axle.mov
So now I have had a quick look
  7210 Hits
08/06/08 - Rons' Jimny
Here is a real little beauty we came across at the AWDC event at Hogmoor today.
  10258 Hits
2/6/08 - More drive train issues
Well following my day out and the June 2008 TV4x4 event at Avon Dassett a few more problems raised their ugly heads. We had a good days driving but it is a long haul back on the motorway for such a small, modified vehicle and it really took its toll.
  6357 Hits
