Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
How to centre the steering wheel after a lift
Following lots of comments on Facebook etc. I decided to produce this video to clarify the process of getting the steering wheel straight after a lift. Its a simple process requiring two spanners and 10 minutes of your time!
If you have a particular video you want me to make to answer a question then let me know!
  6036 Hits
Tags:
Fitting spring silencers
PXL_20210115_111938225-1
I have been plagued by a twittering squeak from the suspension. When working on our Gen4 Jimny I realised that there were spring silencers on the bottom of the springs. Therefore I bought a set for BigJImny, here is the video
  5558 Hits
Tags:
Charging a Gen4 Jimny
MXS_5.0-web-big-1
With a lot of Jimnys being "weekend" or hobby cars, battery life can be an issue. This video takes a quick look at battery charging
  5536 Hits
Tags:
Changing a CAM sensor on a Gen3
ADK87202
Having read the fault codes, I needed to change the CAM Sensor, so it was out with the video camera for a new video.
  4878 Hits
Tags:
Code reading a Gen3 and Gen4 Jimny
Screenshot_20201226-155811-2
An error code on BigJImny gave me an excuse to roll out my Code Reader to see what was wrong and also look at Gerald (LittleJimny) to see what the reader can see.
  2603 Hits
Tags:
