Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
Modifications and Upgrades to our Gen4 Jimny
Resized_IMG_20200504_185045
Over the past few months I have been carrying out some little modifications/upgrades to our Gen4 Jimny and created some video guides.......
  6440 Hits
Tags:
Baofeng DM-9HX DMR
Notes on the programming and use of a DM-9HX DMR Radio.
I have put these together as a simple reminder to myself on "how I did it" and also as a help to others. The challenge with Digital Radio is that it is binary, it either works or it doesn't, there is no inbetween version of "I can just hear you " or "it nearly works". Playing around with DMR, you will hear a lot of silence!
DMR for Amateurs has evolved from commercial digital systems such as Tetra etc. This means the firmware code in radios tends to be similar to that you would expect to find in a police/security/PMR device, ie. channels are all pre-programmed and the end user has little or no control over channel settings in day to day use. Therefore a lot of the work setting it up is done from the computer and not the radio. Apparently a high end radio such as the Anytone 878 will allow much more Amateur "on the fly" programming, but the Baofeng DM-9HX is only around £65 so the intelligence is in the computer setting up and not the radio.
  8897 Hits
RockLobster Build - Part 3 - Re-assembly
Processed-IMG_20200112_19104013
​This three part article covers my building of a RockLobster 6.5:1 transfer box. The article parts are:
  • Part 1 - Dis-assembly (see HERE)
  • Part 2 - Building the gears (HERE)
  • Part 3 - Re-assembly (this part)
  6730 Hits
Tags:
Keithy's Trayback
20200110_183845
Has power been an issue for your Jimny?
It's not an issue here! Check out Keithy's Trayback build
See Read more...
  7100 Hits
Tags:
RockLobster Build - Part 2 - Building the gears
Processed-IMG_20191218_08453828
  • Part 2 - Building the gears (this part)
  • Part 3 - Re-assembly. (see HERE)
The kit I am using (Trail Gear) contains gears and parts to replace/add to an SJ Transfer box. Within an SJ transfer box are effectively three gearsets/shafts as follows:
  • Input shaft - The Trail Gear set contains a replacement shaft to which you add either the original bearings or new bearings as you prefer,
  • Counter shaft - The Trail Gear set contains a replacement shaft and gearset to drop in,
  • Output shaft - The Trail Gear set contains replacement gears for the original gears, you either re-use the original bearings or new bearings as you prefer.
  5942 Hits
Tags:
