Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Subcategories from this category:
Old Man Emu vs Des Sol
Lil Red SJ - Steering Vibration - Second step
IMG_20220802_105335101
Yesterday I took the SJ to the Tyre Centre and got all 4 wheels balanced. I chose to do all four so I can mix and match the wheels around the car without worrying about balancing. With the wheels balanced the drive home was much better, but not perfect. The "wobble" we are getting is not a death wobble, its more of a mechanical vibration. Our ...
  3412 Hits
Tags:
Lil Red SJ - steering vibration
20220320182702-1d59c67d-me
James' SJ flew through its first MOT with us last week and then typically we detected a vibration in the steering  this weekend despite nothing being reported. Now long term Jimny owners know all about "Death Wobble" and worn Kingpin bearings, however before stripping it all apart there are some initial basic checks, the first of which is...
  3544 Hits
Tags:
Fitting spring silencers
PXL_20210115_111938225-1
I have been plagued by a twittering squeak from the suspension. When working on our Gen4 Jimny I realised that there were spring silencers on the bottom of the springs. Therefore I bought a set for BigJImny, here is the video
  5502 Hits
Tags:
How to centre the steering wheel after a lift
Following lots of comments on Facebook etc. I decided to produce this video to clarify the process of getting the steering wheel straight after a lift. Its a simple process requiring two spanners and 10 minutes of your time!
If you have a particular video you want me to make to answer a question then let me know!
  5972 Hits
Tags:
Charging a Gen4 Jimny
MXS_5.0-web-big-1
With a lot of Jimnys being "weekend" or hobby cars, battery life can be an issue. This video takes a quick look at battery charging
  5485 Hits
Tags:
