Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
From Jimny to Willys Jeep - Part 6
Resized_IMG_20191204_094825
George has completed his Willys jeep build based on a Jimny and sent in these pictures as a conclusion. If you remember, this is the project built using a "new old" Jeep tub i.e. a brand new tub built to the original spec in one of the original Jeep factories. I think it looks really good.  The picture below shows where this all started.
  9207 Hits
Tags:
From Jimny to Willys Jeep - Part 5
It runs! Click the title to see the video
  9322 Hits
Tags:
From Jimny to Willys Jeep - Part 4
 George is progressing well with his build. The floorpan and rear sections are complete.
  9368 Hits
Tags:
From Jimny to Willys Jeep - Part 3
 George has sent in a couple more pictures showing the join in the body tub where it was extended to fit the Jimny chassis
  29752 Hits
Tags:
From Jimny to Willys Jeep - Part 2
A further update from George on his Jimny to Willys Jeep conversion.
The "genuine" Willy's Jeep tub has turned up (they are still being manufactured by one of the original licensed Jeep manufacturers in Belgium so its a "New Old" tub)
As you can see in the picture below the chassis is longer than the tub. In the UK the law is pretty flexible around what you can do to a vehicle without having to jump through paperwork and engineering hoops. However, the "certification" and identity of a vehicle is considered to remain with the chassis, therefore chassis modifications (cutting etc.) are more difficult to get approved. Therefore the easiest option is to extend the body.
  10564 Hits
Tags:
