Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Hi,
Just purchaced a 2005 jimny, and it is stuck in 4wd, no lights on dash
Tried working the switch with all 4 wheels off ground.
Removed the switch and found no power going to the plug on the switch, checked 20amp fuse under dash and all good.
Any ideas how to proceed, which wire is supposed to have power to switch, as could run a temp...
Hi,
Any ideas how to proceed, which wire is supposed to have power to switch, as could run a temp live to see if that works.
When you turn key on ignition the only 4wd light to come on in dash is 4L, is 4H supposed  to come on?
Any ideas??
There are no blog posts currently available
