Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Subcategories from this category:
SJ Rebuild
From Jimny to Willys Jeep - Part 2
A further update from George on his Jimny to Willys Jeep conversion.
The "genuine" Willy's Jeep tub has turned up (they are still being manufactured by one of the original licensed Jeep manufacturers in Belgium so its a "New Old" tub)
As you can see in the picture below the chassis is longer than the tub. In the UK the law is pretty flexible around what you can do to a vehicle without having to jump through paperwork and engineering hoops. However, the "certification" and identity of a vehicle is considered to remain with the chassis, therefore chassis modifications (cutting etc.) are more difficult to get approved. Therefore the easiest option is to extend the body.
  7712 Hits
Tags:
From Jimny to Willys Jeep - Part 1
Processed-IMG_20190605_1145021
Sick and tired of your Jimny being called a Jeep?  If so then why not make it a Jeep! George Atkins has kindly sent in pictures of his build in progress........
  6224 Hits
Tags:
Another SJ Build - Sam's Yellow SJ - Back on track
A while ago I posted some pictures of Sam Emery's SJ rebuild, unfortunately at the crucial moment the Welder he had lined up to do the welding was no longer able to do it.  Therefore there has been a very long wait until the next update.
However, he has now found another welder and more progress is being made.
I am sure from following James' Lil Red SJ rebuild that you will recognise exactly the same issues and repairs being done to this SJ.
The rear wings needed replacing.
  5811 Hits
Tags:
Lil Red - SJ restoration - Final Paint - Part 1
Processed-WhatsApp-Image-2023-05-05-at-17.27.0114
This week we reached the final stage of the build at Winchfield. The SJ went into final paint.
This is a long post so scroll on down!!
In order to do this the main panels had to be finally fitted. In this procss it was noticed that the front cross members did not fit properly into the new wings. Again this was due to the poor manufacturing quality of the wings.
As you can see the alignment is poor.
  5490 Hits
Tags:
Lil Red - SJ restoration - Fettling and Paint
Processed-WhatsApp-Image-2023-04-21-at-15.35.331
When checking the panel alignment, Winchfield Engineering noticed a slight dent in the sill that we had not seen, On our model of SJ this part is normally covered by a black rubber strip so it seems likely that the sill had gently contacted something and got bent but it was hidden behind the rubber,
Therefore they had to pull the dent out and remove it.
  4931 Hits
Tags:
