Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Subcategories from this category:
SJ Rebuild
New tyres (update)
Jimny_IMG_20180208_132358
When I ordered my new tyres (see here)  there were only 4 in the UK. However I have found one so now I have a proper spare. Its all very heavy on the rear door but thats a problem to tackle another day. Very pleased as it now looks like a Jimny!
  6465 Hits
Tags:
Heavy Duty Transfer Box Rubber Mounts (update)
sized_Jimny_IMG_20180130_201301
Quick update: I have been running the ZookBOB heavy duty transfer box mounts for a week now and can report a very noticeable drop in "noise" from the Transfer Box. The transmitted vibration from the box to chassis and rest of the Jimny has gone! A whole made Rocklobster is never going to be quiet but this one just got a lot better.   ...
  5786 Hits
Tags:
sized_Jimny_IMG_20180130_190552
The standard Jimny rubber mounts are notoriously weak when the Jimny is used in anger offroad. It is common to break one, you find your transfer box lever suddenly leans to one side or the stick seems to disappear into the floor and everything shakes and rattles.
In the early days of modifying Jimny's, everyone developed Polybush style heavy duty mounts. Indeed I have a set of mounts which were early production models from Off-road armoury. However, the material used in Polybush items or variants is hard and unforgiving. Yes, it is long lasting and tough but it does not lend itself to comfort. That is why I got rid of my caster correction bushes in the radius arms and went back to rubber based ones, to improve the ride.
The same can be said of the transfer box. The heavy duty polybush style mounts on mine have lasted well but they transmit every vibration and bump onto the chassis and body work.
  7539 Hits
Tags:
Getting an identity
sized_Jimny_IMG_20180111_130503
I have had the Jimny over 10 years now and in that time it has never had any badges. When I purchased it there was no badges on it and I did not do anything about it.
  5996 Hits
Tags:
Dual Battery monitor
dualbattery2
BigJimny has dual batteries fitted. A slightly enhanced standard battery for starting and a large battery in the boot for the winch. Having just replaced the batteries when rebuilding BigJimny, I decided to put a monitor in. A quick google showed a number of expensive systems but also a new cheap system from the Chinese discount sites.
  5429 Hits
Tags:
