Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Subcategories from this category:
SJ Rebuild
Axle breathers
As part of the rebuild I decided to fit my own axle breather kit. My Jimny has the old "hosepipe" style which was large, untidy and the hosepipes had hardened off over the years.
  6316 Hits
Tags:
Rebuilding the front
jimny_IMG_20171110_185655
Having previously re-built the rear suspension it is time to sort the front. Again this is a KAP 3" lift with Pro-comp shocks and this is where the main "sag" is.
  6622 Hits
Tags:
More goodies arrive!
Jimny_IMG_20171109_210355
As we all get older things sag at the front, just ask anyone over 50! My Jimny is heavy and my old springs have worn out. However when compared to the new springs the old ones are actually longer! This is more about turns and wire diameter. The new ones have an extra turn and are made of 13mm wire compared to 11mm so I believe they will hold up rather than just compress and sag like the old ones. I can actually press the old ones by hand!
Still, there is a lot of weight up front so I decided to give the springs a fighting chance.
  6044 Hits
A quick test
IMG_20171107_191549
Having got the new tyres on the rims I could not resist a quick test. I still need to change the suspension on the front of the Jimny so it still looks a little wonky,  The rear suspension is complete so the wheels can go on and stay on. There looks to be sufficient clearance based on the cutting that was done for the previous tyres. I might h...
  7573 Hits
Tags:
Finished off the rear axle
JimnyIMG_20171028_194347
 So I am finally there on the rear axle. All finished and back on her wheels.
There were a few "cosmetic" items to sort.
First was the air feed for the ARB locker. The old feed had been damaged when the axle parted company from the car in 2011 (see It all goes wrong).
I had previously fitted the new parts for the feed to the diff (see  Fitting the rear wheel bearings)
  6130 Hits
Tags:
