Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Subcategories from this category:
SJ Rebuild
Fitting rear bump stops
JimnyIMG_20171012_183031
The key to a good suspension set up is balance and stability. Over stretching in any direction achieves very little. Ok so the vehicle may seem to have amazing "articulation" but if the tyres are not generating traction (ie pressing on the ground) it does not matter how far they have stretched to touch the ground. Bump stops are a way of protecting the suspension from over compression on one side and the tyres from rubbing inside the wheel arch. Therefore, with a new set of springs and shock I also have gone for bump stop extensions
  5074 Hits
Installing the diff, shafts and brakes
IMG_20170923_194017
Work has continued over the last couple of days with the re-assembly. First the differential was replaced. I ensured the filler and drain plugs were removed (because this would have been an ideal time to "unstick" them if they had corroded in position) and then cleaned up the housing face.
I then coated the face with sealant, lifted the differential into place and bolted it up.
  4007 Hits
Tags:
Re-fitting the rear shocks
jimny_IMG_20170920_075756
​As you can see from the pictures showing the "orange" springs, I was supposed to be creating a lift based on 3" (or 75mm) components from Trailmaster. However I must have accidentally sold the shocks I had put aside. Therefore for now I have fitted a pair of Rough Country N2 which I still had around from when I sold them.
  4153 Hits
Tags:
Rear wheel bearings
regal2250_IMGA0242
So a miracle occurred and I did some more work on my Jimny today. First of all I repaired the ARB air locker tube that had been damaged. The threads had been pulled out in the brass mounting so I had purchased a repair kit and refitted the fitting.
You can see the original damage in this article - https://www.bigjimny.com/index.php/bigjimny-blog/problems/entry/812-arb-air-line-repair and the photos below show the new parts alongside the old.
  7627 Hits
ColinK's Jimny
ColinK's Jimny
ColinK has sent in some pictures for display in the gallery, thanks Colin
  7093 Hits
Tags:
