Gen 4 internal rattle
  • DrRobin
  • Platinum Member
  • Platinum Member
  • Newbie in Northumberland
10 Dec 2024 21:51 #258680 by DrRobin
Hi,
I have a rattle on the passenger side at low revs (less than 2000rpm) coming from somewhere around the passenger airbag, top of the dash or possibly from the front of the door.
Is this a common thing like the loose dashboard on a Gen 3?  I have had my passenger try pushing bits of trim when it does it, but unfortunately it doesn’t do it for long and have so far failed to find the problem.  I have also felt around for anything loose, but again not found anything.
Anyone out there had the same thing?
Robin
10 Dec 2024 22:06 #258681 by jlines
Replied by jlines on topic Gen 4 internal rattle
I found the sensor box up the top of the windscreen to rattle on my SZ5. It sounded like something around the dash by the drivers side but ended up being that box. Try putting your hand against it when it starts rattling. It would also be weather dependant when it rattled. It seemed worse on colder mornings and better when it was warm. We put some plastic inside which has helped it. I haven't had the same issue with my LCV.
1986 SJ413JX (Lil Red)
Pending...........
2019 SZ5 (Gerald)
2023 LCV
  • DrRobin
  • Platinum Member
  • Platinum Member
10 Dec 2024 22:26 #258682 by DrRobin
Replied by DrRobin on topic Gen 4 internal rattle
Thanks James, I will check the sensor box tomorrow. I was going to mention temperature, it doesn’t rattle all of the time, but I haven’t yet decided if it’s when it’s cold or warming up.
From the driver side it sounds like the top of the dash, but could be coming from further up. Hopefully it’s not the windscreen coming loose.
Robin
10 Dec 2024 22:37 #258683 by mlines
Replied by mlines on topic Gen 4 internal rattle
If you play with the sensor box be careful you do not snap off the little retaining tags. Don't remember how I learned that ;)
11 Dec 2024 07:23 #258684 by Soeley
Replied by Soeley on topic Gen 4 internal rattle
I sometimes get a slight rattle from the glove box contents. Opening it and closing it sorts it out.
11 Dec 2024 11:38 #258687 by 300bhpton
Replied by 300bhpton on topic Gen 4 internal rattle
I have a rattle that I can't locate, what exactly is the sensor box you mention? Thanks.
Time to create page: 0.687 seconds
