Front Diff - Locked on not?
- Thank you received: 1837
05 Jan 2025 19:14 - 05 Jan 2025 19:15 #258997
Replied by Lambert on topic Front Diff - Locked on not?
Be polite, don't hide behind acronyms especially when they can be interpreted as rude, aggressive or sweary. BE NICE!
Last edit: 05 Jan 2025 19:15 by Lambert. Reason: Predictive text
05 Jan 2025 20:17 - 05 Jan 2025 22:46 #258998
by 300bhpton
Replied by 300bhpton on topic Front Diff - Locked on not?
Apologies, however I thought/felt that was a polite reply, was meant more in jest…. Maybe it needed an emoji??
About 40 sec of effort on Google:
You can download the manual as a pdf, so should help the op with the specifics of the 4wd system as well as other aspects of the car.
Last edit: 05 Jan 2025 22:46 by 300bhpton.
05 Jan 2025 21:09 #258999
by Steve G
Replied by Steve G on topic Front Diff - Locked on not?
05 Jan 2025 21:44 - 05 Jan 2025 21:47 #259000
by Busta
Replied by Busta on topic Front Diff - Locked on not?
I have a welded front diff in my Jimny and I can promise you it drives a lot differently on tarmac to a standard Jimny in 4wd!
A Jimny is the same as any other part time 4wd. There's no centre diff so use 4wd on loose surfaces only.
Last edit: 05 Jan 2025 21:47 by Busta.
06 Jan 2025 06:13 #259004
by Motacilla
But there is also an expectation that an adult takes some measure of responsibility. There is a certain measure of due diligence one should cover before plonking down tens of thousands of pounds. One can certainly opt not to do one's homework before buying -- or in this case, even afterwards -- but then one should probably anticipate a little hooting from the gallery.
All of which is beside the point of this thread, which I think has been pretty thoroughly covered by the helpful people on the forum. Good job all. @300bhpton, you are forbidden to use the "F" key for a bit.
Replied by Motacilla on topic Front Diff - Locked on not?
I'm all for being nice. 100%Be polite, don't hide behind acronyms especially when they can be interpreted as rude, aggressive or sweary. BE NICE!
Time to create page: 0.189 seconds
