1998 Jimny, rear wheel arch liners?
06 Oct 2025 22:52 #262198
by rhino666
1998 Jimny, rear wheel arch liners? was created by rhino666
Hello
I am tidying up the old Jimny back end before winter sets in and the rear arches look quite vulnerable with no liners, just a little cover protecting the fuel filler on the o/s, removed in photos.
There is what looks to be a liner mount strip with fixing holes on each side but it seems the Gen 3 Jimny was not fitted with rear arch liners. Can someone confirm that my photos are normal and arch liners are generally missing and not required.
Thank you
Thank you
06 Oct 2025 23:47 #262199
by Hughes
Replied by Hughes on topic 1998 Jimny, rear wheel arch liners?
I will happily be corrected but don't think there ever was an inner liner from factory.
At least I've never seen one.
- Darthblaker7474
- Elite Member
- Thank you received: 33
22 Oct 2025 18:33 #262410
by Darthblaker7474
Replied by Darthblaker7474 on topic 1998 Jimny, rear wheel arch liners?
Without looking on mine, I'm pretty sure there's a small arch liner covering the fuel filler pipes.
22 Oct 2025 21:49 #262412
Replied by yakuza on topic 1998 Jimny, rear wheel arch liners?
Better to top up the underseal with easy access, than to get liners to hold dirt and moisture?
23 Oct 2025 21:51 #262435
by rhino666
Replied by rhino666 on topic 1998 Jimny, rear wheel arch liners?
I brushed Hydrate 80 on the areas where rust was showing, mainly the back end inboard and the outer leaf of the arch. I then applied a product called Sovereign K10; it's a resin based roof sealer with fibre glass strands. This took days to dry and I was then able to spray with Holts/Simoniz black Gloss tough paint.
It looks like you can buy some sort of aftermarket rear liners but no sign that these were ever fitted at the factory. An arch liner is only any good if it effectively seals out water and mud. The ones I found don't look like they would do that, so it seems available arch liners and probably rear flaps will cause more problems than they resolve. .
Time to create page: 0.275 seconds
