04 jimny 3" lift advice
03 Sep 2022 12:53 #244842 by Scot The Sniper
im back as everyone sighs lol the jimny has been of the rd since my last post and i bought panhard rods 4 weeks ago and now there evantually fitted. i have a 04 jimny in for repair i have meassured his front and rear panhard rods from bolt hole to bolt hole and rear is 15mm out and front is 8mm out i hope this is ok to do it that way or is it not adive please. p.s i need one radious arm bolt for this other jimny as i had to take the radius arm of to weld a bit on it and snapped the rear radious arm bolt that was even with heat if anyone has a spare to send me i would be so greatfull as you can only but then in 4x bolts p.s im glad to be back its been of the road since my last post i was depressed with it lol and iam glad to be back as this forum has a great bunch of ppl on here hope to hear back from you soon. scot
04 Sep 2022 11:53 #244858 by Scot The Sniper
Thank you very much Jack also looking for a rear lower shock absorber bolt as well Jack?
12 Sep 2022 12:44 - 12 Sep 2022 12:46 #244934 by X8GGY
Last edit: 12 Sep 2022 12:46 by X8GGY.
23 Sep 2022 19:11 #245090 by Scot The Sniper
Ok more woes I have fitted and adjusted front and rear panhardrods took it for a drive and it is better but I think I need it the 4 wheel alignment done as I'm sure there out big time as when I got back to my garage air bag light on code B1021 and Google says if horn not working its the clock spring behind the wheel the ribbon has snapped so steering must be well out advice plz
24 Sep 2022 09:09 #245093 by jackonlyjack
Did you notice the steering wheel was not in same location as before the lift?
Drive it in a straight line, get out and look where the pitman arm is off bottom of steering box
Ideally it should be sat in line with the chassis leg see picture below.
If it's not then you will need to undue both ends of steering drag bar hub and steering box the one in front of axle.
Keeping both front wheels on the ground rotate the drag bar till pitman arm is in location in a straight line with chassis leg.
However this will probably not fix your airbag light situation
Time to create page: 0.144 seconds
