Massive MOT failure - is it worth saving
04 Feb 2025 13:56 - 05 Feb 2025 08:46 #259339
by Forde
Massive MOT failure - is it worth saving was created by Forde
I've had my 57 plate Jimny for almost a year now. I bought it privately and it had 11 months MOT with 1 advisory (minor leak of gas from rear exhaust). I've not had much done to it since buying, just the swivel seals and kingpin bearings at the front if I remember correctly. I've put it in for MOT this morning, and it's failed in a big way...
Do not drive until repaired (dangerous defects):
My question is, is it worth saving? The body work is pretty tidy; not dents and only some very minor rust spots. The interior is very clean. I still owe £2,300 on the loan I took out to buy it. I love it and need a vehicle but I don't know if I should cut my losses. My local garage won't know the full extent of some of the jobs until they do some more investigating but they have said definitely over £1000 and quite possibly nearer £2000.
Any advice would be much appreciated.
Regards,
Sad Jimny owner
- Offside Front Outer Brake pad(s) less than 1.5 mm thick (1.1.13 (a) (ii))
- Offside Front Inner Brake disc significantly and obviously worn surface (1.1.14 (a) (i))
- Nearside Front Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
- Front Windscreen washer provides insufficient washer liquid (3.5 (a))
- Anti-lock braking system warning lamp does not illuminate (1.6 (a))
- Exhaust Lambda reading after 2nd fast idle outside specified limits (8.2.1.2 (c))
- Rear Brakes imbalanced across an axle n/s weak (1.2.1 (b) (i))
- Nearside Rear Service brake effort inadequate at a wheel (1.2.1 (a) (i))
- Nearside Front Headlamp aim too high (4.1.2 (a))
- Offside Front Headlamp aim too high (4.1.2 (a))
- Exhaust has a major leak of exhaust gases rear of cat section / silencer area (6.1.2 (a))
- Offside Front Inner Suspension component mounting prescribed area excessively corroded significantly reducing structural strength anti roll bar mounting area (5.3.6 (a) (i))
- Offside Front Brake hose excessively chafed rubbing on coil spring (1.1.12 (b) (ii))
- Nearside Suspension component mounting prescribed area excessively corroded significantly reducing structural strength mid chassis outer area (5.3.6 (a) (i))
- Rear Brakes imbalanced across an axle Axle 2 (1.2.1 (b) (i))
Regards,
Sad Jimny owner
Last edit: 05 Feb 2025 08:46 by Forde.
04 Feb 2025 16:21 - 04 Feb 2025 16:23 #259341
Replied by mlines on topic Massive MOT failure - is it worth saving
That doesnt look too bad to me.
Probably the most important is to get the codes read from the ABS system as a new pump is quite expensive but if its a sensor then its an easy fix
Most of the other are simple to correct (headlight aim, washer jets, wiper blades etc.)
Then rebuild the front and rear brakes should clear most of the others. Couple of plates on the rust and a new exhaust and your back again for much less than the outstanding finance. A good small garage mechanic could sort that all for you (depending on the abs pump of course)
I know of a couple of garages in Berkshire that would sort it for you. I would get the ABS codes read as a first step
Last edit: 04 Feb 2025 16:23 by mlines.
The following user(s) said Thank You: Forde
- Thank you received: 534
04 Feb 2025 16:38 #259342
Replied by DrRobin on topic Massive MOT failure - is it worth saving
The have been quite hard on you with the screen washers, they probably just need a needle to clean them out and the headlamp alignment could have done there and then.
I know it's a long list but quite a few are easy fixes and as Martin says the other more complex stuff might not be too expensive.
04 Feb 2025 17:34 - 04 Feb 2025 17:37 #259346
by Forde
Replied by Forde on topic Massive MOT failure - is it worth saving
Thank you both. You've made me feel a bit better about it. I'm really annoyed that some of the issues were clearly passed on the last MOT, when they should've been failed, but that's a life lesson I suppose.
I'm think I'm going to persevere. Will get them to look at the unknowns first, in particular the ABS, and go from there. I really didn't want to write it off and buy something boring.
Last edit: 04 Feb 2025 17:37 by Forde.
04 Feb 2025 17:46 #259347
by gv42
Replied by gv42 on topic Massive MOT failure - is it worth saving
We can do all the work it needs but we are in N/WALES
04 Feb 2025 18:51 - 04 Feb 2025 18:52 #259349
by lightning
Replied by lightning on topic Massive MOT failure - is it worth saving
lt's surprising how many faults can appear in 12 months. lt was probably okay last year although if it's now got corrosion bad enough to fail an MOT l would have expected it to be an advisory last year.
Last edit: 04 Feb 2025 18:52 by lightning.
Time to create page: 0.160 seconds
