Massive MOT failure - is it worth saving
05 Feb 2025 08:03 #259358
by Forde
Replied by Forde on topic Massive MOT failure - is it worth saving
It's a shame I'm so far away from you (far south west Cornwall) as I'd really like to use someone who knows Jimnys. I rate my local garage but they're definitely not Jimny specialists
- Rogerzilla
- Premium Member
- Thank you received: 13
05 Feb 2025 08:22 #259359
by Rogerzilla
Replied by Rogerzilla on topic Massive MOT failure - is it worth saving
The ABS light can just be due to LED brake bulbs. These usually trigger an intermittent ABS fault unless they have the right inbuilt resistors. Put normal bulbs back in and it's fixed.
05 Feb 2025 08:41 - 05 Feb 2025 08:45 #259360
by Forde
I believe the ABS has been completely disconnected but not 100% sure on that
Last edit: 05 Feb 2025 08:45 by Forde.
- Thank you received: 1854
05 Feb 2025 09:49 #259361
Replied by Lambert on topic Massive MOT failure - is it worth saving
With the one exception of the arb mount it's all just mechanical and therefore relatively straight forward, I'd be rather more concerned if it needed a lot of welding as that's beyond most people to do properly. Sticking with it is the future.
The following user(s) said Thank You: Forde
05 Feb 2025 09:53 #259362
by Forde
Thanks for that, again making me feel a bit better. My local garage don't seem at all phased by the welding side of things.
05 Feb 2025 15:43 #259368
Probably not but there's mot welding and there's repair/restoration welding, they are not the same.
Time to create page: 0.171 seconds
