Stalling/Failing to start after manifold removal/replacment
- Darthblaker7474
Topic Author
- Elite Member
- Thank you received: 36
07 Nov 2025 18:38 #262659
by Darthblaker7474
TL;DR Stalling immediately on start up (while squealing) after removing intake manifold
In order to find where coolant has been leaking from (after replacing the thermostat housing) I've removed my intake manifold for a better look. Got it all back together the first time, started her up, and petrol was leaking from one of injector!. Sorted that out (put then back in). Started the car again and it was leaking from the injectors again. Reseated them, went to start the car and it wouldn't turn over at all.
Turns out I'd dislodged the trigger wire from the starter, so again I took apart the manifold, put the wire back on, and after a few days of waiting replacement injector seals arrived I got those back on. Anyway as you can see in the video , start her up and she is immediately stalls out all the while screaming like a banshee. If you blip the throttle it'll run but very rough.I've also gone and bought a new battery (which I probably didn't need) so we should be able to rule out that.
Does anyone have any ideas? Even if they aren't very good.
2008, M13A
2008, M13A
- Thank you received: 1926
07 Nov 2025 21:46 #262660
Replied by Lambert on topic Stalling/Failing to start after manifold removal/replacment
Sounds a bit like it's pulling air somewhere could be wrong, have you looked at the vacuum lines?
The following user(s) said Thank You: Darthblaker7474
- Darthblaker7474
Topic Author
- Elite Member
08 Nov 2025 12:01 #262663
by Darthblaker7474
Replied by Darthblaker7474 on topic Stalling/Failing to start after manifold removal/replacment
As far as I’m aware they’re all back in together. Is there any specific ones I Should pay particular attention to?
I refitted the one for the fuel rail not long before making this post, still no avail.
The squealing could be a pulley grinding as I hadn’t started the car in a week or so… maybe? 😬
- Darthblaker7474
Topic Author
- Elite Member
08 Nov 2025 15:50 #262664
by Darthblaker7474
08 Nov 2025 16:31 #262665
by Motacilla
Replied by Motacilla on topic Stalling/Failing to start after manifold removal/replacment
Are the water pump and alternator turning freely?
- Darthblaker7474
Topic Author
- Elite Member
13 Nov 2025 20:29 #262725
by Darthblaker7474
Time to create page: 0.589 seconds
